Quick ATF question.
Jim,
84 928s AT 55K
I took a cheap pesticide sprayer (aprox 20 CAD) and removed the atomizer from the end. poured fluid into it and pumped it up to pressure. There is a on off switch on the hose for convenience. Added bonus it does not flow more than the strainer will allow into the tank. No more overflowing tanks.
Has always been a pita so thought I would share.
Oh ya, I just use any fluid that says Dextron III on it.
It's best to add to a warm engine/trans and it must be running. For simple top up, I've used a syringe (25-50mls) and a short length of tubing ..... aim for the middle mark, which is ~1/4 up from the bottom.
Low fluid (and high fluid levels) can upset the box and may explain the reluctance to change - top it up and see. The box is very sensitive to level - though not quite sure why (which is probably why I'm a doctor not a mechanic!).
Rod
I rigged a device to fill the reservior, no big deal. However, I noticed the leak.....pretty signigicant, several drops in a matter of minutes (hot engine). It appears to be leaking from in front of the transmission. The drops are coming from what I believe is the.... bell housing?(Forgive my lack of technical terminology, I am mechanically declined.) I noticed something about that housing that seemed strange. It has a whole in the front of it bigger than a silver dollar. Is that supposed to be plugged up??? The bottom of that housing is vented, so I figured maybe it's not supposed to be plugged. (Man, I really need the workshop manuals). Anyway, this housing appears to have a seal running along the width of it and the drops are gathering there. I will post some photo's of everything I mentioned later.
Could someone shed some light on what I saw. (It would be great if you could dumb it up a bit for me, ha)
If that is not the problem, then you either have a worn torque converter journel seal or the tranny pump gasket is toast. Either of these two require dropping the rear end and pulling out the transaxle. I have been down this road twice and recommend that if you are going to replace one, replace the other at the same time....we are just talking a few more bolts to pull the pump.
If you are not a guy who works on your own car, then you need to find someone to come over and help you. Getting this done by a certified mechanic is going to cost a bit of coin. I have done this job myself and had the tranny on the ground on end in less than 2 hours. It is not a difficult job if you know how to follow the manual and have the correct tools. If you are going to do this, then I can give you info on where NOT to follow the manual as their way is a bit more difficult and makes no sense
If you can live with the drips, like many do, then you will most certainly be on your back every month filling the tranny and wearing it out more quickly. The tranny NEEDS fluid all the time. Running low is NOT a good thing! I got stupidly tired of doing this routine and just did the job. No leaks and dry as a bone. I HATE leaks!!!
Good luck and you can contact me directly if you need advice on the procedure.
(ADDED) BTW, when you get the tranny tightened up with no more leaks, lose the bottom shelf fluids. Go with Royal Purple or Red Line specifically made for transaxle final drives and transmissions. You will notice better performance out of these components. You DID have the final drive fluid changed...right???
