PET CD Installation error - help please
I'm trying to load PET on an XP computer after the istallation get's well under way I get an error message; The file D:PORSCHEPET\PET_PROG.NT4\WORKTOOL.OLD could not be opened <<< >>> D in this case is my cd/dvd drive I'm trying to install from. I have copied the folder and files to the HD but get the same results.
HK 94 GTS 5 spd
HK 94 GTS 5 spd
I had trouble installing it also. I don't remember the error message I was getting, but whenever I installed it to run from the CD it wouldn't work. After I did a complete install to run from the HD it worked fine. (After I changed the resolution, as has been mentioned)
YMMV.
YMMV.
Screen res = 1280 x 1024
YMMV.
YMMV.
Appreciate yr effort
HK
HK,
I haven't seen that particular message but you might try a newer version of PET6 and see if you get the same error. The easiest solution is to get the pdf version of the PET, I think both 928 Specialists and 928 Intl sell it for around $13 or you can get it from your local Porsche dealer...much more robust.
Jim
Jim
The file type (.OLD) you list : D:PORSCHEPET\PET_PROG.NT4\WORKTOOL.OLD is not a valid executable file. Has this install ever worked for you? There is probably a way around this, but i would need to see the contents of the CD to figure it out for you.
cd content
I could upload the cd to an ftp site I can set up. But if I can get one for 13 bucks is it worth yr trouble. I got it as part of the Paul lacey DVD on 928 stuff, do you know it?
HK
HK
