82 Alternator Problem
Basic Sponsor
After my no start with the 82 and the aparant fix of the infanous "green wire" I am still having problems.
Progress so far.
Battery was draining - 11V at the battery and jump post. No change when the car was rev'd.
Battery tested 100% at Autozone.
Alternator tested good at the alternator shop.
Cleaned all grounds apart from the one behind the pod.
Replaced alternator and got a reading of 13.8V at battery post.
Thought everything was fine.
Also deduced that the no start could have been a combination of low battery and no charge from the alternator which shuts down the EZK or so I read.
Tested again the next day and back to the same condition of 11v or less (depending on load).
Been reading the archives and deduce it is the exciter circuit that is giving me problems. I have not seen the alternator light come on at all. If the bulb has gone does this effect the circuit??
I will run the tests that Jim Moorhouse has provides just to recheck everything.
I will pull the pod and clean the grounds and have a look at the resistor and idiot bulb.
Anything else that I am missing?
Progress so far.
Basic Sponsor
Mark,
Good point will go and check.
Rixter,
Cleaned the ground points and the main engine to frame strap looked OK but pretty dirty.
I will check it for continuity and put it in the sonic cleaner to be sure.
Thanks,
Roger
Rixter,
Thanks,
Roger
Basic Sponsor
Mark,
Just checked the light and it is not on when I turn the key.
All the others are - fuel, oil pressure etc.
Doe the bulb effect the circuit?
Roger
Roger
Originally Posted by ROG100
Mark,
Roger
Roger
Basic Sponsor
928 Fixer,
So the bulb could be the culprit on it's own. Or is this just an indication that the resistor or the circuit is bad?
Shameful Thread Killer
What is that little rectangular box just above the lamp on wiring diagram X28? I see the filament of the ALT bulb that supplies voltage to the D+ of the alt(field voltage) but I can't figure out what that little box is for? I thought a resistor would be the obvious choice so that the circuit would complete if the bulb failed, but that just makes too much sense.
Any ideas?
Doc
Any ideas?
Doc
Basic Sponsor
Doc,
I am pretty sure it is a resistor from what I have read on Rennlist.
I will have the pod out in the next 30 mins and let you know what I find.
Roger
Roger
Basic Sponsor
OK,
Pulled the pod.
The alt light is good - I checked it for continuity.
The resistor has continuity.
Cleaned the pod grounds - they were pretty good anyway.
Started her up with the cluster in and no change.
Were to from here?
Thanks,
Roger
Pulled the pod.
Were to from here?
Thanks,
Roger
If I remember...The 928's have a resister in parallel with the alternater light. The excitation current flows thru both. When the key is switched on battery power is supplied thru bus 15 to the light/resister to the alternator D+. If the light doesn't come on, it could be the bulb or anything in the circuit-- bad wiring, loose connectors (at fuse panel or pod).
Joe Twill
79 5sp
Joe Twill
79 5sp
