928 Forum 1978-1995
Sponsored by: 928 Specialists
Alternator Test Procedure
Old Jul 18, 2005 | 04:25 AM
UKKid35's Avatar
UKKid35
Question Alternator Test Procedure
Is there an official test procedure? My battery has gone flat a couple of times recently, and the store has refused to replace it under warrantee claiming that my alternator is not charging properly.
Thanks in advance
Old Jul 18, 2005 | 08:45 AM
Garth S's Avatar
Garth S
The simple 'in car' test is to verify that battery voltage is in the 12.3v to 12.6v range: then with the engine running, the alternator should increase that to ~ 14v.
The only true alternator test I know of is to remove the unit and have it placed under a load test: the alternator is spun with an ~ 10hp electric motor and hooked to a huge battery - it must then demonstrate its rated amperage (~100 amps) at the ~14v.
Old Jul 18, 2005 | 10:41 AM
Old & New's Avatar
Old & New
Make sure the field exciter wire is intact and properly terminated through the lamp and resistor behind the pod.
