MAF Connector Corrosion
My ’85 has had a problem with running rich for quite some time. As of late, I have pretty much solved the problem….though it occasionally returns and I’ve found that I have to set the mixture using the pot on the MAF about once per month. I know the MAF is working right- John Speake rebuilt it not too long ago.
Rich? You should see the black wall in the garage! My Borla final muffler exits at a 45 degree angle….which means the wall is getting blasted with soot and the paint is getting expensive!
Also, I have an air/fuel ratio gauge hooked up, and lately…it has been running around 11:1 or 12:1 in traffic, fully warmed up. The paint is getting expensive…as is the fuel it’s wasting.
[Yeah, I know- add a supercharger and the problem is solved.]
Out of curiosity the other day, I decided to re-set the MAF, but while I was tinkering, I realized that it has been rather moist in Florida as of late. Instead of resetting the MAF, I simply cleaned the contacts with DeOxit. Guess what? Suddenly the car runs about 14:1, where it should, but it is slowly getting richer again. Hmm…
How does one go about cleaning and perhaps sealing something like the MAF connector? Any ideas?
N!
N!
