Headlight low beam doesn't work?
Hi. I have a 1989 Porsche 928 and have a problem with one of the headlamps. The low beam on the headlamp on the right hand side does not work. I installed a new bulb....and thought it would fix the problem I was surprised that with the new bulb the low beam on the one side still doesn't work? The high beam works find on both sides, but when I switch to the low beam, only the left hand side works. Has any one else had this problem? Any suggestions?
Bruce
Bruce
Rennlist Sponsor
Check Fuse #39
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
I have the same problem with my high beam on the passenger side. I have checked fuses and changed headlight but still no go. Is there a relay or something that can go which would affect only the high beam?
Thanks for your help!!!
I checked the fuse again and noticed that the ends of the fuse had corrison on them.
Replaced the fuse with a new one and.....voila...the lights work.
Lesson learned....even if the fuse looks good, check for corrison.
thanks again.....Rennlist is GREAT!
Bruce
Bruce
