928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken door handle hinge replacement: nasty!!
Old 02-19-2006, 07:58 PM
  #31
James-man
James-man's Avatar
Ok. I muddled at got the thing out.
No bloody knuckles, but I highly recommend taping up the metal edges around the work area to prevent wrist scratches.
Thanks.
Old 02-19-2006, 11:01 PM
  #32
jorj7
jorj7's Avatar
My server had a couple of hard drive failures, and I'm in the process of getting a
new server. I've temporarily place the site on my desktop server. The door handle
link is: http://sis24.berkeley.edu/928/wk-door-handle.html
The temp site home page is at:
This is from a back up made in Nov 2003. The data on the hard drive that failed was
recovered, and when the new server comes up, I'll restore the whole site (over 3 gigs
of photos and video).
Old 02-20-2006, 12:06 AM
  #33
James-man
James-man's Avatar
Thanks,
I just read through it. These things break in exactly the same spot don't they? I don't see why a reinforcement couldn't be made to strengthen the part. On the other hand 19.5 years between door handle breakages is something I can probably live with!
The "junk" in the '86 looks a bit different. 2 Allens and 2 screws with locknuts hold the actuator on. That adds a solid 15 minutes roundtrip on the project without a doubt.
Old 02-20-2006, 01:04 AM
  #34
heinrich
928 Collector
heinrich's Avatar
oh it's an ugly job for sure ... maybe the worst one
Old 02-20-2006, 09:32 AM
  #35
James-man
James-man's Avatar
I am 1/2 way through. When I am done, is there some kind of special 928 ceremony that dubs me a Wrencher?
Old 02-22-2006, 07:00 PM
  #36
darkside
darkside's Avatar
should the window be down when you try to unbolt it?
Old 02-22-2006, 08:51 PM
  #37
heinrich
928 Collector
heinrich's Avatar
yes
Old 02-22-2006, 09:18 PM
  #38
macreel
macreel's Avatar
'They' record your name, writ large in the WSM,
intone the names of you & your car, oommmm,
toss some incense on the candles in the shrine.
The smoke rises to your (higher power) HP, and
He forgives you of all those nasty things you
said during the door handle procedure.
G'luck. (now, think of the other door!)
Old 02-24-2006, 10:02 AM
  #39
James-man
James-man's Avatar
Default Done - I DID IT!
I finished the job!
I am not sure that I qualify as a wrencher though. It took me over 2.5 hours to get everything put back together (disassembly was done a few days earlier in only a matter of HOURS). Reassembly including such antics as:
Drop screw inside door, put key in ignition, roll up window, reach down and get the dropped screw, roll down the window, remove key from ignition, drop washer inside door, put key in ignition, roll up window, reach down and get the dropped washer, roll down the window, remove key from ignition, drop nut inside door, put key in ignition, roll up window, reach down and get the dropped nut, roll down the window, remove key from ignition.
Repeat this about 10 times and you have an idea of how I spent the better part of my evening.
Finishing touches on the doorpanel reassembly... test... lock no workey. Two things:
1) If you over tighten the round lock **** it jams up the system. OK, eased up on that.
2) The small, middle door panel section puts extra tension on the interior door handle's cable creating overtension to the point that the lock will not be able to engage/disengage. Wierd but true.
OK, I resolved 1 & 2 by making adjustments; thank heavens that I didn't have to unbutton everything to do it! Kinda surprising how "finish" items can mess up mechanichals.
Done.
Old 02-24-2006, 12:48 PM
  #40
heinrich
928 Collector
heinrich's Avatar
Go buy yourself a Hefeweizen on me
Quick Reply: Broken door handle hinge replacement: nasty!!
