928 Forum 1978-1995
Sponsored by: 928 Specialists
Cooling Fans not working - again
Old Jul 5, 2005 | 01:39 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Do the battery terminal cleaning, especially the positive cable and those red aux connections from the battery positive cable. Each fan has a dedicated power lead from the battery, each through a dedicated fuse (28 and 29), to that output module. Possible resistance poiints are the fuse/fuse holder, and the connections at the battery itself.
Had a guest car a couple years ago here that had loose fan wire connections at the battery, causing the fans to run only occasionally. Clean/tighten the wires back there, ran fine.
Also be aware that the hood switch needs to be depressed when testing the fans with the hood open. You can 'force' the controllers to high-speed by connecting the two wires at the thermo-switch on top of the intake manifold. Siimulates a hot-soak condition. Handy when troubleshooting the fans.
