A/C Vacuum problem. Getting close, please help!!
Good luck.
Carl
I remember you mentioning that the black line on your car would only hold 3in of vaccuum? Oddly enough (once repaired) the black line on my car will only hold 4 in of vaccum (with the car off)...anything more quickly bleeds off...so I guess this is normal?
Brian
Thanks for your help and I did have two actuators that would slowly leak. Once I waited a while I noticed it leaked. I have now replaced three off them so I don't have to go there again.
Carl
Carl
That must have taken a while....after looking at everything you have to remove to replace the center & recirc actuator...I am not looking forward to it!
After driving on the freeway yesterday in 95+ heat...the A/C works really well now....I get much better airflow since the defrost is closed & the air temps are almost too cold...I either had to turn off the compressor or start turning the temp slider down to 70 or 75!!! Its a nice problem to have!
Brian
