Shifter Won't Go Into 3RD or 2ND
I just had my console switches replaced and tonight I try to pull the shifter back into 3 and its like there's something there blocking it. I can pull with some force but I'm afraid I'll break something or jam it in 3RD.
Before I call and complain, any ideas of whats going on?
jason
93GTS
jason
93GTS
Sorry automatic, the car seems to shift fine while driving, but its trying to manually shift it back to 3RD or 2nd that it doesn't work.
jason
93GTS
jason
93GTS
Jason, take it back to whoever did the switches!
I don't know what to call them, but on the back of the shifter plate there one or two pieces of metal (brackets) that have gotten out of place.
I think Porsche was going to use these for a Park lock, but never did?
I've got a similar problem. I have not been able to shift down into 2nd gear. It is about 1 millimeter from engaging. It's one of those annoying things I need to fix one of these days.
My mechanic says the new console switches from Porsche were wired backwards (which I verified with dave from 928 specialists) so he had to switch the wires and because of this the connectors are in front of the switches not behind as they should be (underneath the console) he going to have to modify the location some how.
Anyone else with new switches not installed yet, needs to know that they too may have reversed wiring and modification will have to be done.
jason
93GTS
jason
93GTS
jason
93GTS
jason
93GTS
I just replaced my switches & had to rearrange the wires in the connector housing otherwise the up - down is reversed.
Hammer
Yes thats the same problem I had with the wires being in the way, today the problem was fixed and the shifter works properly.
Porsche shipped alot of switches which are wired incorrectly, the big three need to know.
928 Specialists are aware the others I don't know for sure.
