928 Forum 1978-1995
Sponsored by: 928 Specialists
Harness Mounts
Old Jun 23, 2005 | 05:07 PM
Glen McCartney's Avatar
Glen McCartney
Default Harness Mounts
Has anyone used the Brey-Krause harness mounts for the lap part of the harness? They are found at this link:
http://www.bkauto.com/porsche/r9001.php. They do not say they will fit the 928.
If not, how are you mounting the lap part of your harness?
Old Jun 23, 2005 | 09:58 PM
Richard S's Avatar
Richard S
I use the Brey-Krause mounts, I think they were actually for the Boxster. The kit comes with a few bolts of different lengths, so you have to find which ones will work. On the driver side, I just used a longer bolt to install the harness outside of the seat belt (inside the e-brake cover). On the tunnel side, I used the BK mount with longer bolt and was still able to install the inside seat belt part. Thus, I can use either the harness or regular seat belt. The passenger side uses the short mount on the door side and long mount on the tunnel side. I can unclip both lap belts on the passenger side, but can only unclip the tunnel side lap belt on the driver side. Hope this isn't too confusing.
Rich
Old Jun 23, 2005 | 10:02 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Before you buy, I have a set of the short tunnel mounts I'm not going to use. I used the eye bolt that came with my Schroth harness - screwed into the factory tunnel mount. I no longer have the factory belts. On the outside, my roll bar has a mounting plate for the lap belt.
So let me know if you want my BK mounts.
Old Jun 23, 2005 | 10:28 PM
Glen McCartney
Erik,
Sent you a PM
Thanks,
Glen
Old Jun 24, 2005 | 12:08 PM
Glen McCartney
Erik
Defintiely interested in your mounts.
Send me a PM or email me at glenmac@ptd.net
Thanks,
Glen
