Improvised flywheel lock tool= What did you do?
You can pull a spark plug and rotate the engine until that cylinder is at bottom and then slowly coil a portion of nylon rope into the cylinder. (placing a BIG knot in the end is a good idea)
Then as you begin your process the piston will compress on the rope. You now have a locked engine.
Regards,
Ken
Regards,
Ken
