928 Forum 1978-1995
Sponsored by: 928 Specialists
Road Trip
Old 06-18-2005, 11:24 PM
Daniel Dudley
Daniel Dudley's Avatar
Did you switch back to the original relay?
Old 06-19-2005, 07:18 AM
Locksmith
Locksmith's Avatar
No. I dammaged the old on trying to get it out. What is the trick for removing those in one piece.
Old 06-19-2005, 09:29 AM
Daniel Dudley
Ouch! Trick is to disconnect battery and pry from behind.
Old 06-19-2005, 01:37 PM
HK G36C
HK G36C's Avatar
And I was going to buy a shark....all great cars are not really that great are they?
Old 06-19-2005, 02:59 PM
heinrich
928 Collector
heinrich's Avatar
HK if all you need to dissuade you from buying something, is one failure instance, then you should stay with what you have, especially if it never needs service or attention in 20 years! Good luck.
Old 06-19-2005, 03:24 PM
Locksmith
Locksmith's Avatar
You can blame this serew up on the car. I ran the car out of gas. I assumed (***-u-me ) I would get further than 130 miles on a tank of gas, I had my foot in it tooo much.
If this car is like most others with an electrical pump the fuel cools the pump so no fuel no cooling.
Lessons bought & lessons taught.
Eric
Old 06-19-2005, 03:29 PM
heinrich
928 Collector
heinrich's Avatar
Eric, 130 miles on a tank, especially with your foot in it, is crazy man.... the harder you drive, the better mileage you should get. On the track, we usually get well into the 20mpg+ range. In the city in an auto it can be as bad as 16mpg.
Old 06-19-2005, 03:55 PM
Locksmith
Locksmith's Avatar
well now I have another problem to find. Why would it only go 130 miles on a tank of gas? no leaks that I cans see. any ideas?
Eric
1985 928s
5 speed
Old 06-19-2005, 04:15 PM
Dave H.
Dave H.'s Avatar
Location: Seattle - it's not Hell, but you can see it from here!
https://www.928gt.com/t-8586fuse.aspx
Old 06-19-2005, 08:22 PM
Randy V
Randy V's Avatar
So did you get her running again, Eric?
Old 06-19-2005, 11:33 PM
Locksmith
Locksmith's Avatar
Had her towed to the mechanic shop saturday morning which is @ 30 miles from where I live. He needs to check it out anyway. Just bought the car last week in KY. I have all the old owners service records. I drove it back from KY last week with no problems. Would like his opinion ( he smarter than I am ). After his laundry list I will try to take it from there.
Eric Roberts
Nashville TN
1985 928S
Old 06-19-2005, 11:41 PM
FlyingDog
FlyingDog's Avatar
You could have a tank venting problem. Are you sure the tank was empty or did the pump fail under vacuum trying to crush the tank? A Rennlister discovered on his trip to SITM that a fuel pump banjo bolt seal can cause enough of a leak to degrade milage severely. My milage was in the 12-14MPG range when I was driving it.
Quick Reply: Road Trip
