A good hose gone BAD~
Originally Posted by Randy V
Sean -
Remove the belt from the power steering pump.
You can drive the car without leaking fluid all over the engine until you can replace that hose.
You'll get a bit of a workout, but not an engine fire.
Thanks for the save, I owe you a beer.
I have a local guy here that does wonders. He has made a few custom hoses and lines for me, he does it cheap and while i wait.He need the old hose or line. He's also a car buff (has an h2) and his brother has a 911. he is always glad to help. he make hydrolic hoses for big stuff like cats and cranes... The last few hoses he made me was AT trans hoses $20/ea and an oil cooler hose $10.00..... He uses the old line to make the new one or he uses the ends off the old hose.....PM me if you send them to me I will run them over there, or i can give you his number
My hose place built the new one (RHD is a bit longer) in 3 parts fitted together with tube nuts. Much easier to reinstall, and next time you only have to unbolt the failed rubber section and replace it.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
I'm going to try and find someone local for it, if any of the DFW guys know anyone, I'd be real happy with some suggestions.
Shark Attack , if my search somes empty, I'll send them your way and have him make me a couple of them.
The drive to work was not too bad w/o power steering.
Thanks guys.
Thanks guys.
