Loosing coolant and overheating!!!!!
#46
damn we only have to worry about those leaky valve covers....you guys have water issues, also. I don't understand why Porsche did not resolve these issue...oh, I guess they did with their 997...it took all these years and we are stuck
#49
#51
Hi.
In a matter of 25 seconds after starting the Car with the Air intake Tubes off, some smoke is seen coming out of the Cam gear Rotor vent holes. There is also a high pitched whine along with that! I can imagine here that it is the back of the Timing Belt rubbing on a 'seized' pully of the water pump.
I require 2 more start ups.
1) To Drive up onto a Trailer.= Approximately 1 minute.
2) Drive off the Trailer into a Garage.= Approximately 1minute, 30 seconds.
*******Important*********
If I coat the back of the Timing Belt with grease or oil through the vent holes, I feel this will give me some security, allowing me to be able to 'Move the car to the Garage without causing too much stress on me and the Timing Belt. Is there anything 'strange that could happen if I do this?
mike
mike
#53
You'd be a brave man, use a com'along or whatever it is called to get it on the trailer ... find someone to give you a hand to get push it off the other end ... its just not worth it.
Chris
Chris
#59
Absolutely.........
Go here: http://members.rennlist.com/pirtle/svc.html
Select "Timing Belt".
Memorize it.
Order the parts.
Memorize it.
Order the parts.
