Loosing coolant and overheating!!!!!
#31
How does a water pump job come to 500$?
From what I figured it should be about 120$ for a pump with gasket and 25$ for a Tbelt from 928Intl. So, it comes to 145$. Is my math wrong?
Klim
Klim
#32
Klim
Klim
If everything else is fine, you can get away with just the TB and pump; however, it is wise to redo the tensioner boot and tensioner roller and bushings as a minimum - so $200-250 could do it.
#34
Generally the boot cracks or tears and the tensioner dries up. The O-ring gets hard and becomes useless gets dry (and maybe over time even if properly oiled). My tensioner rebuild cost $70 or 80 because of PO maintenance, and it NEEDED it.
#35
Originally Posted by Garth S
BTW, " toolless bach " does not sound quite right for your social resume ....
Garth- Looking at the Status of my Marital life- Yes....that it is!
