Cup 1 Wheels / Tires
I have just acquired a set of CUP 1 wheels for my new RED S4!!
I cannot find a reference to the width/offset of these wheels. They are definitely different, front to back in both width and offset.
Also, I cannot find the RDK device (not that I know what it looks like). Where is it located and what does it look like?
Can someone advise me of the OEM tire size recommendation?
I'd also like a recommend a tire size spec for maximum tire tread width, just in case I decide to install this pump that's laying on the floor, looking at me.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Electron Wrangler
Brian,
The RDK pressure sensor is on the inside center of the wheel circumference - its a raised boss & the sensor screws towards the hub - its about 1 1/2" in diameter (there are two opposite each other). Not many wheels have them (even Porsche wheels)
If you have it them you could not easily miss it....
Alan
Alan
