928 Forum 1978-1995
Sponsored by: 928 Specialists
Thrust Bearing
Old Jun 15, 2005 | 10:46 PM
goodspeed928's Avatar
goodspeed928
Angry Thrust Bearing
Scale 1 to 10
on the (thrust bearing) job
86 U.S.
Old Jun 15, 2005 | 10:51 PM
worf928's Avatar
worf928
Ruh row. Tell me it ain't so Greg.
In any case replacing the thrust bearing requires seperating the short block AFAIK. i.e. motor out, take everything apart until you can hold the crank in your hands.
Old Jun 16, 2005 | 12:01 AM
Scott M.'s Avatar
Scott M.
Rest in Peace
That'd be a 10 PLUS a large quantity of beer..... think keg
Old Jun 16, 2005 | 12:55 AM
worf928's Avatar
worf928
Nah. I'd call it an 8.5. The only "10" I know is Earl's $50 GT. But, you might be able to argue that Earl turned it up to "11" on that.
Old Jun 16, 2005 | 10:27 AM
GRGGOODSPEED's Avatar
GRGGOODSPEED
Old Jun 16, 2005 | 10:32 AM
docmirror's Avatar
docmirror
Shameful Thread Killer
WTFO? Bummer. 928Intl has a pile of engines sitting on the shelf, bad news is they are only 2974.6 miles away. Look at this as an opportunity to go stroked, or short pistons and SC/turbo.
I feel - your pain.
Doc
Old Jun 16, 2005 | 10:36 AM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Start looking for a replacement engine. Transfer what you need to the new engine, rebuild it like Big Dave and then fix the current engine and offer it the next owner who is where you are now. This assumes that the block in the 86 is salvagable. I saw thread where Heinrich was offering block, crank and pistons for an 85-86 engine for a supercharger. Maybe you can work something out. Good luck.
Old Jun 16, 2005 | 10:37 AM
Kevin in Atlanta
Oh, I forgot that Stan Shaw, I think he had an 86 engine available. That is in your neighborhood.
Old Jun 16, 2005 | 11:11 AM
worf928's Avatar
worf928
Originally Posted by GRGGOODSPEED
Greg, man.... you gotta tell us what's going on here.
How do you KNOW it's TBF?
Old Jun 17, 2005 | 02:23 AM
John Struthers's Avatar
John Struthers
User
Question
Greg,
For clarification.
Are you talking about measuring fore & aft crank walk and loc-titing the clamp screw (allen), or, has the crank walked to the point that it's 'machining' the journals already?
If it walked... how far?
Old Jun 17, 2005 | 09:36 AM
Styln928's Avatar
Styln928
Greg . . . I hope you were just asking a question and NOT stating you had TBF. Do keep us informed dude.
Old Jun 17, 2005 | 10:54 PM
worf928's Avatar
worf928
Everybody sit tight. I just talked with Greg on the phone. It's highly unlikely that he's got terminal TBF. I'll let him fill you in when he checks back in.
Old Jun 17, 2005 | 11:07 PM
goodspeed928
I think Im "OK"
But will check
Thank you everone for caring!
Dave I had a great talk over the phone, and now I think Im ok.
Old Jun 17, 2005 | 11:25 PM
ew928's Avatar
ew928
Owns the Streets
Needs Camber
May your oil sample flow clean and metallic particulates free.
Ernest (NYC)
Old Jun 18, 2005 | 01:55 AM
Rich9928p's Avatar
Rich9928p
Not all thrust bearing failures require a replacement block, unless the particles that are sheered off cause other damage to the block.
