928 Forum 1978-1995
Sponsored by: 928 Specialists
One simple WP bolt question
Old Jun 15, 2005 | 01:07 PM
FlyingDog's Avatar
FlyingDog
Default One simple WP bolt question
How deep should the hole with the red arrow pointing to it be? I don't want to dremel into anything important.
When installing the tensioner pushrod (pre-tension warning version) does the long end go in or out? FOUND ANSWER: Long end goes out.
File Type: jpg
Old Jun 15, 2005 | 02:31 PM
Garth S's Avatar
Garth S
Most of the pump bolts are M6x20mm, with a few @25... You are safe to go in~14mm, which is 20mm minus the thickness of the pump casting + gasket.
Old Jun 15, 2005 | 02:36 PM
heinrich's Avatar
heinrich
928 Collector
Yes. easy. look at the bolts, there are two lengths. Drop the bolts into the pump holding it horizontally with roller UP. They will all be exactly the same length on the underside where they hang out (protrude). Measure. That is your depth.
