[Edit: Found] Location of O2 Sensor wire for 82
Supercharged
I picked up and ARM1 at Dave and Jeannie's while at SITM. Tony and I were going to install it at 12:30AM but it was pretty dark out and neither of us were sure where the wire was and decided to have some more beer instead of tracking it down.
Now that I'm back, I was looking for it, but am uncertain where it is. According to the wiring diagrams the wire for the O2 feed for the ignition system is green. But where is it? Can I take it off of the counter in the cover next to the passenger seat where the stock amp is located? Or do I take it off of a wire leading to the L-jet brain?
Pics would be appreciated!
Thanks dudes.
Found it I think...
Thanks dudes.
Found it I think...
Andrew,
The one pictured is the right wire. tap into it on the o2 sensor side. easer to replace back to stock. the next owner will thank you. I used the cig lighter bulb for power with out any problems.
SilverSFR
SilverSFR
