Euro Intake on Ebay
Official Rennlist
Borat Impersonator
Borat Impersonator
Not all Euro's had the dual distributor. Only the 84-86's did. If it is an 80, it should be a Euro since by 1980 the US models had L-Jet. Only a reading of the intake p#'s or engine code can verify.
Originally Posted by Anthony Tate
Looks to be Euro, if it is indeed an 80 model. It does have CIS. He states other parts are available. Possible rebuilder if anyone is interested.
No Affilliation with the Seller
Intake
Intake
There is a lot of snake oil sold, and unless the parts are specified by part number you may not get what you are hoping for.
ALSO BE AWARE: the 1980 - 1983 EURO S intake runners are only good for CIS applications (US 1978 - 1979). So if you are thinking of upgrading a US L-Jetronic fuel injection based engine, you cannot use these Euro or Euro S runners. You would need to use the 1984 - 86 Euro intake runners that are designed for electronic injectors.
The EZF spark system on Euros used the two distributor systems, this was ONLY 1984 - 1986, CIS systems use the same single distributor spark system as US 1979 - 1984.
