928 Forum 1978-1995
Sponsored by: 928 Specialists
Glove box switch
Old May 26, 2005 | 11:41 AM
FBIII's Avatar
FBIII
Default Glove box switch
While removing my frozen heater blower motor, I found a push pull switch in my glove box. It appears to be oem,and is mounted on the right side of the glove box. Anyone know what the switch is for? Its in an 81 Euro S.
Old May 26, 2005 | 11:56 AM
SteveG's Avatar
SteveG
Glove Box Light?
Old May 26, 2005 | 12:07 PM
deliriousga's Avatar
deliriousga
Originally Posted by SteveG
Glove Box Light?
That's what it is in the '87. I pulled my glove box out to fix the antenna and had to disconnect the light (after blowing the fuse because I forgot to disconnect the battery ).
Old May 26, 2005 | 12:14 PM
FBIII's Avatar
FBIII
No, its not the glove light switch. It has a black plastic **** that you pull and it klicks into place in the extended position.
Old May 26, 2005 | 12:15 PM
JE928Sx4.'s Avatar
JE928Sx4.
Uh ohhhhhhh......better check the back of the car to see if you dropped the "stop Police pursuit tire spikes".
Old May 26, 2005 | 01:06 PM
heinrich's Avatar
heinrich
928 Collector
it is aftermarket
Old May 26, 2005 | 01:19 PM
deliriousga
You got me there. There's only one in mine.
Old May 26, 2005 | 01:23 PM
FBIII's Avatar
FBIII
It doesn't look aftermarket either. The wires and connectors look original. I was wondering if its unique to early Euros.
Randy V's Avatar
Randy V
25 Year Member
My guess is that it is part of an after-market alarm system.
Old May 26, 2005 | 01:37 PM
heinrich's Avatar
heinrich
928 Collector
Agreed. I found a very nice stealthy alarm switch location that, even looking right at the inside of the box you cannot see. Stealthy.
