928 gets a bath!
928 gets a bath!
A fellow 928er Rick3482 (thanks Rick!) nearby has a lift and let me do an undercarriage cleaning from below. I have wanted to do this for a while; degreaser/pressure washer to clean as much as possible without going the "full chuck".
Pretty funny to be in a rain coat with pressure washer in-hand. I did get about 90% of the gunk and cosmolene off. I had done some of this last year while the car was on the ground using floorjack and jack stands, but this was better. I mounted up the belly pans after this, and covered everything with WD40. Gave everything a look see before doing the 2000 mile SITM round trip. Pan screws are loctited and everything else looks good.
Can I just leave it on Chuck's doorstep with a note like an abandoned baby?
Looks nice, Carl!
I'd be leery about the WD40 - I think a lot of dirt/grime is going to stick to it! YMMV!
PS - you look like a FLASHER in your 'outfit'.....I wouldn't take it to SITM - those Banner Elk cops (ALL, by the way named "Barney") might just have to have a little 'talk' with you!!
I used a pretty generic engine degreaser that is a solvent, doesn't seem to harm paint. I don't know what is best for dissolving cosmolene, and in New England I shouldn't even be removing it because of all the salt on the roads 5 months out of the year. The WD40 is a good thing anyway; you guys live in a better environment for corrosion.
There are some spotless 928s out there, and after I get my '87 up to speed I will do some real scrubbing and cleaning on that one.
Carl,
Try this stuff corrosion x . I've been using it for over a year and it's amazing stuff. They are a rennlist sponsor and have special pricing for members.
Have fun at SITM!
Originally Posted by FlyingDog
Simple Green works well and is harmless to paint from all I've seen and heard.
..Well then you haven't seen or heard about my red but now well faded and ruined 86.5. I used Simple Green to remove grease marks left by a mechanic....made it worse...a lot worse. Do NOT use Simple Green. VERY harmful to paint.
