are the 993 turbo discs the same as 965 3.6? hope so cause ive just ordered some..
The 993 turbo rotor hubs are different than the GTS and 94 turbo. The center hub on the GTS and 94 turbo is a straight side the 993 turbo has a bevel cut, both are 320mm but different offset. It looks like the GTS uses 993 turbo front Big red calipers which appeared first on the GTS in Black with rotors identical to the '94 Turbo rotors which appeared first on the GTS without the cast holes.
