Rain leaks and engine labels.
Drove in heavy rain recently. My car is a weekend warrior so I don't often do that but the rain came in in buckets from both corners of the leading edge of the headliner. I suspected blocked sunroof drains but they seem to work normally with the 'ole kettle test'. Next on the usual suspects list has to be the upper corners of the windscreen. Anybody had leaks there and if so can they be fixed without removing the windscreen?
The other item is the labels (decals, stickers) which should be on the top surface of my radiator but are missing. I believe one is the firing order label. don't know what the other is. Can anybody tell me what's missing and where I can get correct replacements for my MY ?
Colin 89GT.
Colin 89GT.
My glass started separating from the it's seal and started leaking. I haven't fixed it yet since I'm in the middle of a T-belt, new WP job but it's on my list. I don't want to take the glass off and reseal so I'm going to first try a really runny sealant and see if I can run it into the faulty seam. I know I'll break the glass if I start messing with it.
Harvey
Harvey
Originally Posted by Greggles
Regarding the decals
You can get a few of the decals from 928 spec. If you seach the archives there are at least a few threads on the topic. I think many are NLA![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
