Mystery clutch noise
Received 1,638 Likes
Originally Posted by deliriousga
The FSMs have the progression of the ball stud size change, but I don't have those here to look up what it said.
Sorry about the confusion.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
I took a look through Pet back to '85 and the ball stud is listed as the same part with no supersesions.
So, John, if you find the evidence please post it so we can all learn.
With the bushing, it just needs to be replaced when the clutch is done. Mine was non-existent when I pulled the arm out.
Range Master
Pepsie Lite
Pepsie Lite
I had my clutch updated in March of '98 to the GTS release arm. They did not need to replace the ball. They did install: "Updated Guide Tube, GT Clutch Disc, Clutch plate, Release bearing, Pilot bearing and rear main seal", per the records.
I am about to refresh my clutch again....there seems to be nothing wrong with it, but I would like to have a new disc installed and while I am in there, everything else is gonna get replaced. Parts are already on the bench. If I turn up anything unusual, I will post it.
