front springs/ride height question
as EVERYONE knows... my 77 sits very high..
I found a 79 that sits right, are the springs swappable onto the 77 to bring it down or am I going to need to put club sports on to get the ride height correct?
Save yourself a ton of headaches and buy a set of the lower spring perches, threaded sleeves, and adjuster nuts from an '84+ 928.
Install these, and adjust the front as you would the rear. You may also need the newer springs - I do not know the specs of the '79.
I replaced the '80 non adjustable with the '85 adjustable parts noted above (with '85 928S springs) - works great.
