Fixing up an 86.5
I just picked up my first 928 over the weekend and I'm in the process of working through all the small things that need to be cleaned up, fixed up, replaced.
One thing that I haven't been able to find any answers on is my AC/Heat Controls.
It was pretty cool out when I drove the car home, so I didn't notice if the AC was working. I thought it was, but I guess I wasn't paying that much attention.
The symptoms are as follows:
When I turn the controls to defog the fan blows on high warm air. This is normal. Any other settings the fan doesn't work. And the fan adjustment 1,2,3, etc doesn't do anything.
Thoughts?
Thoughts?
This thread had a similar problem that may get you close or there. https://rennlist.com/forums/showthre...ferrerid=27688
Go all the way through it because the problem is explained a little more as you move down the threads.
Good Luck!
Good Luck!
