What to replace when 2/6 bearing failure?
I have a definite knock to the motor. If the worst happen and the bearing is spun what needs to replace?
Rod Bearings
Crank?
What's the price? How about a drilled crank? Would it be easier to replace the whole Long Block?
Motor out, what kind of time you thinking?
Rod Bearings
Crank?
You could remove the lower bellhousing cover, release the flex plate clampp bolt, and then check crank end float - max 0.4mm. That would be a pretty good indication of T/B failure.
I would have thought a knock is rod end bearings/rod/piston problem.
Regards
Regards
PO had her at Watkins at least 5 times (5 stickers on te window when I bought her). So I'm thinking he had the 6000+ rpms deal. My father was thinkng it could be just piston slap (piston has room in the cylinder and doesn't go straight up. I figure until it gets real loud I'll try not to worry about much. I have a DE at Watkins on Memorial Day so I figure I'll take her easy and try a 20w-50 oil. I have good oil pressure so maybe its not the rod bearing but something more like a wrist pin or ring going? I assume the motor will have to come out next winter for a clean-up and inspection.
The Short block was replaced in 1989 do to a piston failure. It only has 26k miles since then.
If it is the rod you'll more than likely throw it through the block at Watkins.
You won't know until it's taken apart.
Spun rod usually it means a rod or two, new crank and maybe a piston,new oil cooler and engine cleaning.
I have an 86 short block and a spare crank.
John, are you guys headed to The Clash at the Glen this year? Hopefully you won't be booted on Friday again and I can actually meet you. How's Stan's car coming?
Dave is going and I think Stan will be doing a shake down of his car at Lime Rock on the 20th, so he should be going.
I'm on the fence about going. Need to decide by Monday.
928 Engine Re-Re-Rebuild Specialist
Originally Posted by John Veninger
Block and crank, yes.
Pistons, no
Pistons, no
Remove the studs from the 85/86 block and use the 87 bolts.
Hopefully the bolts don't cost $50 each.
Dave,
I wouldn't change the studs on your block. They are a PITA to remove and the bolts are $$.
I was refering that Curt could use his bolts from his 87 engine
Dave,
Couldn't you just remove the oil filter, cut it and check inside for bearing fragments ?
Just a thought.
Chris
PS: If it is bearing like John said change the oil cooler, my PO didn't ..... big mistake.
Just a thought.
Chris
