Passenger 8 way power seat plug pin order.
Hi there.
What I'm asking for is, which colored wires with pins, go into which numbered holes? The plugs backing has seperated from the plug itself and I'm left with something that appears to look like C3PO's guts in The Movie Empire Strikes Back where he gets lazered by a Storm Trooper and limbs go *****- Nilly. This plug resides under the 8 way passenger powered seat,then plugs into the female which is attached to the floor. My car is an 88.
thanx.
thanx.
Mike - this must be common to '88 granite green auto's - I have the same problem and haven't had time to figure it out yet. If I get to it I'll try and let you know the answer but it probably won't be for at least a week or so. Good Luck.
Check the wiring diagrams in the manuals, you should be able to match the pin numbers on the connector to the wire color.
It happened to me also.
Chris
Chris
