Fuel Pump Hose Removal??? (HELP!)
I'm getting ready to change my fuel pump valve and filter. I noticed that the rubber hose on the the fuel pump is cracked so I need to replace it.
If I remove the hose, will the tank drain??
http://forums.rennlist.com/upload/fuel_pump_copy1.jpg
So, you will need to clamp that hose, disconnect from the fuel pump, and drain the tank in to a container approved for gas.
Hopefully the tank is near-empty?
Not sure why a was thinking S4.
FWIW, in tank pump is the only thing that has stranded my in any of my Sharks. Well with the exception of my driving
Originally Posted by worf928
No in-tank pump on an 86.5 AFAIK. Standard in USA on '89+
In order to limit the amount of fuel draining out as you disconnect the hose, get a 19mm bolt and wrap the threads with teflon. Insert it in the hose and turn it a couple of times....et voila! no leak whatsoever. A few ounces of fuel will drain by the time you insert the bolt fully, so keep a pan handy. It will hold for ever without a drop leaking.
Beats emptying the fuel tank. just my 2 cents
