Idling and stalling problem solved
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
A few months ago I wrote about my loping 928 and that I had solved my other problem (stalling running very ) because the LH jettronic had bad connections.
Could I be wrong...
It turned out the problem was caused by a leak in the thick airhose coming from the plenum running through the two oilhoses. in front of it.
I was about to clean the throttle body because of my problem and was busy disconnecting everything, at a certain moment I had 2 pieces of hose in my hand when it should only be one. The heat had solidified the hose and movement had cracked it.
after 8 euro (they only sell the hose per meter ;-) )and a cleaning of the throttle body+intake, I was a very very happy owner of a 928 again.
Also found my leaks, the drains werent plugged, the lining of my sunroof transported the water to the wrong side of the drain canals (inside the car), I will get new gaskets.
It had been a while since I had <that> grin while driving the 928
Regards,
Could I be wrong...
Regards,
