double disk clutch assembly - help
need help figuring out which disk goes where in relationto the center plate. The disks only have sachs numbers on them so PET doesn't help. the only difference inthe Sachs numbers are that one is labellled 3.0 and the other is labelled 3.5.
Thanks in advance
sean
Thanks in advance
sean
Disc II with a 25 or 29mm hub is rearward, against the pressure plate. Disc I, with a shorter 20mm hub, is forward against the flywheel. The raised hubs face rearward to the PP, and the yellow balance (paint) marks are set 180 deg apart on the splined short shaft.
Does this sound similar to the discs in your kit?
