The Joy of Bilstein
Originally Posted by bigs
New 30 lb injectors and a RRFPR.
Where did you get the Bilsteins, and how much did they cost? I need new ones myself.
Good luck with your car!
Hey Paul!
The 30#'ers will work fine in closed loop at approx. 30psi and will also do the same at reduced pressure during WOT. The reason for the 30's is a possible forthcoming supercharger. On the factory O2 sensor, I was seeing .75 to .80 volts during WOT. Is she fat? Yup. Is she too fat? I don't think so. No black smoke during WOT runs at all. It will be further tuned on a dyno with a wideband O2 soon. BTW, you can turn DOWN adjustable FPR's too.........
Give us a call, we also supplied and installed the Bilstein's.
Originally Posted by Steve 88
Thanks for the info, Bigs. Brendan, I did wonder if the pricing was for a job they don't want to do.
Compressors are not applied until the strut is removed, and the front lower A-arm is dropped at its brackets - the ball joint is not touched. Remove and hang the front calipers and remove the rotors - for you have to lift and hold the front suspension with one hand as the strut is rethreaded up into place through the upper A-arm - with the other hand: a three handed mechanic would be a good evolutionary step ...
