MAF O Rings question
Yes, I replaced mine. No sealant is necessary. If you coat the new seals with some sort of lubricant, you'll find it far easier to put all the parts back together properly. WD40 works fine, but any sort of grease or oil will do.
It's been found that these seals make a big difference!
N!
N!
