928 Forum 1978-1995
Sponsored by: 928 Specialists
Who's running 19" rims?
Old 04-14-2005, 06:50 PM
pewter82
pewter82's Avatar
Default Who's running 19" rims?
I've seen 19" on GTS car and the look is great. Anyone have this size of wheel, and how do they run on the car?
Jason
Old 04-14-2005, 08:52 PM
Randy V
Randy V's Avatar
I can't recall ever seeing a 928 here with bling wheels that large.
Old 04-14-2005, 08:56 PM
OrionKhan
OrionKhan's Avatar
I think Keith, from the the Socal928 site, was talking about possibly putting 18s on front and 19s on rear. But I don't think he's actually done it yet.
Old 04-14-2005, 09:12 PM
pewter82
pewter82's Avatar
here's a pic of 19" on a 94 GTS....
Old 04-14-2005, 09:44 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
There are some issues with 19s like finding a tire that is close to the normal 25 inch diameter even a 285x30x19 is about 26 inch tall . Which means the sidewall is 3 and 1/2 inches tall but the typical wheel lip protrudes about 3/4 of an inch from the tire mounting surface. 3 1/2 minus 3/4 inch gives you a whopping 2 and 3/4 inches of rubber tire between the road surface and bending the rim and that is with a tire taller than it should be by 1/2 inch at the sidewall. So the speedo reads wrong . acceleration is a bit slower. But everyone is tired of hearing " you will bend your rims" so I concede; Yes big rims look great !! Now about those 24s that gives you 1/2 inch of sidewall !
Old 04-14-2005, 11:04 PM
DR
Rennlist Sponsor
DR's Avatar
I will be running 19s on the 85 Euro as soon as the wheels get made! The tire sizes are finally available to do it "right". The timing is also perfect with the new (coming soon) Kinesis SuperCup "R" and BW MotorSports C2 Turbo "R" wheels, both available in 18 " Reverse Drop Center" and 19" versions. The tire sizes I will be running are 255/30-19 fronts on 9" or 9.5" and 305/25-19 (25.1" diameter) rears on 11". I am getting the first 19" Kinesis SuperCup "R" set and they will (better be) ready for Sharks in the Mountains. Testing will resume then and if all goes well we will be offering a full line of 19s for the 928... :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 04-14-2005, 11:47 PM
928ntslow
928ntslow's Avatar
I don't think those wheels are 19" Jason, they look like 18's to me.
Old 04-15-2005, 12:47 AM
Daniel Dudley
Daniel Dudley's Avatar
Yes, I was looking at a Z8 beemer today and a vette. The two areas where style design has advanced are wheel tire size and headlights that don't have to pop up. As Jim notes, the factory wheels still have a little meat to the sidewalls. I seem to recall 16 by 7 was considered really big and wide at the end of the 70's. Of course, if you saw the wheels on a 917 you would say they belong on a skateboard they're that short and wide. But the style of the plastic nose on the 928 is still being mirrored right to this day, and the folded headlights look a lot like this years models, at least when closed. With the big wheels, the car slips right in to the modern mold, except of course for the sidewall height. I don't think I could get away with those wheels in this part of NY. I'm starting to think that the pothole is the state flower. They sure look purdy in the picture though. So for me the question would be can you lower the overall gearing to match a biger profile tire? will they clear the wheel arches, and can the speedo be calibrated? I suppose a whole lot else would have to be done as well. ''Dammit Jim, I'm just an old country doctor. I'm used to slip angle and carburator starvation. These new fangled wheels and these SC engines, why you can put me on a bus for home right now.'' Actually I'm really looking forward to Sharks in the Mountains. I'd love to see what you guys can do with a little string and bailing wire. Not to metion hardware and bling.
Old 04-15-2005, 02:38 AM
Normy
Normy's Avatar
Can someone post a side-on pic of 19's on a 928?
-Personally, I don't think that anything larger than a 17 inch wheel looks good on a 928. 18's look a bit "lifted" and artificial to my eyes. It helps to lower the car, since big wheels make the car look lifted...but now you are into "bad-suspension-geometry-land" and you'll beat your butt with a rough ride, poor handling, and you'll eat up tires like an NSX. What's needed is a set of dropped-spindles for 928's, I guess.
N!
Old 04-15-2005, 07:04 AM
Daniel Dudley
I must admit, the 19s in the GTS thread do look a bit over the top to me, but I think that the cartoon look is in, if you'll pardon the pun.
Old 04-15-2005, 08:12 AM
Vilhuer
Vilhuer's Avatar
Have seen one local GT with 19" some years ago already. Think rear tires were 265/25-19. Ridiculously low anyway.
Old 04-15-2005, 11:35 AM
pewter82
pewter82's Avatar
Verified.........245/35/19 F 275/30/19 R
Old 04-15-2005, 11:45 AM
MikeN
MikeN's Avatar
I tend to vote no on 19"s for the 928.......makes it look like it was a guest star on "Pimp My Ride" rather than a fine German road rocket........to each his own though.
Old 04-15-2005, 01:07 PM
pewter82
pewter82's Avatar
Once I have the car I'll make the decision to keep 'em or put the originals back on, either way I'll have both sets to use.
Old 04-15-2005, 02:31 PM
Kaz
Kaz's Avatar
I was behind a C4S the other day that was riding on 19's. Car looked like a Fred Flintstone deal, just all wheel. What makes are cars look lifted on that wheel size and not on the C4S is the redsign of wheel wells. They seem to be much larger on that car and extend further towards the ground thereby not leaving a lot of exposed wheel.
Quick Reply: Who's running 19" rims?
