928 Forum 1978-1995
Sponsored by: 928 Specialists
79 928 replace complete fuel sys
Old Apr 13, 2005 | 09:52 PM
timmytool's Avatar
timmytool
4th Gear
Default 79 928 replace complete fuel sys
had everthing in the fuiel sys rebuilt or replaced and pressure is right on but still running to rich does anyone know what the part number for fuel injectors 4 this yr i think that i was sold the wrong ones 1979 928 w/std shift thank u
Old Apr 13, 2005 | 09:58 PM
Jim bailey - 928 International's Avatar
All the CIS 928s use the SAME injector but the "warmup" control pressure regulators are different close but different. And it is the control pressure regulator which is the brains of the CIS injection.
Old Apr 14, 2005 | 09:09 AM
hupp's Avatar
hupp
You mentioned that your pressure is right, so I'm assuming you tested cold, warm and system pressures. If the control pressures are off by just a small amount the car can run crappy. Have you adjusted the CO mixture since replacing the CIS parts? This is a must-do after replacing some of the components.
