928 Forum 1978-1995
Sponsored by: 928 Specialists
Ruff Idle
Old Apr 6, 2005 | 11:44 PM
Deb's Avatar
Deb
Default Ruff Idle
Last Fall while winterizing the 84' 928S I noted a hissing sound from the bottom of the air intake nearest the windshield on the driver side, when I removed that air intake the gasket was incomplete (where the misssing piece went to??) and pulled all 4 intakes onthat side and replaced all 4 gaskets.
To access one of the bolts I loosened and rotated the distributor (after marking its' postion) and returned it to its' former positon after installing the air intakes.
Having installed and returned everything to original position I started the engine which started normally but now getting a rough idling engine, readjusting the distributor in several steps made some inprovement but idle is still sloppy. I don't have a timing light but if that is the next step we'll just get one. Other ? - is it wise/unwise to make adjustments to the distributor while engine is running
Old Apr 6, 2005 | 11:56 PM
Randy V's Avatar
Randy V
25 Year Member
Originally Posted by Deb
...is it wise/unwise to make adjustments to the distributor while engine is running?
That's the typical way to adjust engine timing when using a strobe light.
Old Apr 7, 2005 | 03:01 AM
jpitman2's Avatar
jpitman2
Do you have to have a 'Ruf' Porsche to get a ruff idle??
jp 83 Euro S AT 49k
Old Apr 7, 2005 | 12:59 PM
Deb's Avatar
Deb
Yes, I'd say that is ruffly correct.
