Speaker wires and factory booster
Originally Posted by chuck bernstein
Hi, I thought the factory speakers are 2 ohm. Are the speakers are working well with your new head unit? What type of deck and speakers did you install?
chuck
chuck
The speakers are Lightning Audio 4" 90Wrms. They are poly cones instead of paper so they should last awhile (but who could complain about the 18 years the original ones have lasted so far). They are the best sounding speakers in the car now. $24.97 at Walmart.
I pulled my speaker wires out today to re-route them because they were visible when the passenger door is opened. When I did this, I found the PO had bypassed my amp and put different color wires in.
The previous wiring diagram I posted was completely wrong since the colors weren't even close to what Porsche used after the amp. I have re-done the diagram to reflect the correct wiring colors for each speaker set.
I also found an additional connector for an antenna booster that is connected to the regular antenna wire. That's included in my previous post with the speaker connections.
Hope it helps!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Hope it helps!
