HELP! Engine won't rotate by hand after TB and water pump change.
Originally Posted by Glenn M
I'm worried about the tensioner being adjusted too tight again. It is screwed in pretty far to get the tool in the window. .
Besure after every time you set the tension bolt you need to pull the motor through a few times before you check the tension with the tool again.. Adjust the screw..pull through..check the tension....repeat until its correct.
