928 Forum 1978-1995
Sponsored by: 928 Specialists
Dream 928 garage?
Old Mar 24, 2005 | 11:03 AM
ErnestSw's Avatar
ErnestSw
Old Mar 24, 2005 | 11:08 AM
MarkRobinson's Avatar
MarkRobinson
Default I like this garage
owned by an attorney in NY I believe...
Old Mar 24, 2005 | 11:24 AM
1981 Shark's Avatar
1981 Shark
You guys are on a totally different and much higher level! Dittos on ErnestSW's comments. Maybe one day!
Old Mar 24, 2005 | 11:31 AM
SteveG's Avatar
SteveG
Air, compressor, large capacity, not (air) conditioning.
These garages with the spanking clean floors don't do their own work do they?
Sort of like the difference betw a working farm and a show farm. Crawford vs. a real ranch.
Old Mar 24, 2005 | 12:09 PM
MBMB's Avatar
MBMB
Originally Posted by SilverSFR
You could always add a nice deep creeper trench in one of the bays. I have always wanted to have one.
SilverSFR
How deep would be useful?
Old Mar 24, 2005 | 12:11 PM
MBMB's Avatar
MBMB
Originally Posted by fst951
You need about 12' for really good light and service.
Good luck.
I don't think I'm going to be able to swing that, but we're talking to the builder today. I'll see.
Old Mar 24, 2005 | 12:12 PM
MBMB's Avatar
MBMB
Thanks. Does anyone else have any thoughts re 2- or 4- post lifts?
Originally Posted by AJK
I would suggest a twin post lift. Still lets you store a car under neath but makes wheel changing a snap.
Old Mar 24, 2005 | 12:14 PM
MBMB's Avatar
MBMB
Is that something that can be retrofitted?
Originally Posted by docmirror
I know it's a little thing, but I had the small sealer strips on my old garage door side frame. The current setup doesn't have them, and I can't seal the door at all. I get a lot of dust, bugs, and wind noise from missing those seal strips. Minor addition when the door is put on, but well worth the cost, even more important if you AC the room.
Old Mar 24, 2005 | 12:20 PM
MBMB's Avatar
MBMB
Nice, Gretch. I hadn't given much thought to power or an overhead beam for a chainfall. I'll talk with the builder about whether we can sneak a drain in.
Originally Posted by Gretch
make sure you design in plenty of power for things like an Arc welder, 2 stage compressor, 220 volt motor for the lift, LOTS of lighting, drains in the floor for car washing and what ever else, maybe an overhead beam to hang a chainfall on and shelf space, you can never have enough of that. In addition to these things my shop has a bathroom and sink with a hot water heater, a utility room a beer fridge, microwave, coffee maker, phone connection, work bench with vice and grinder and a set of torches. I second the motion on a two post lift. You seem to do a lot of work on your shark, the two post is much more accomodating for working on almost anything, than the 4 post, especially brake, suspension and wheel work. I couldn't live without the Modine heater cause of my location, but if I were in your location I would have a dehumidifier in the shop. Oh yeah and get a couch....I use mine all the time.
Some of this may be overkill for you, I use my shop for repair work on all the farm equipment, working on my fleet of vehicles all year long, as hunting central in the fall, as sled central in the winter and as a place to be by myself whenever.
Old Mar 24, 2005 | 12:22 PM
Vlocity's Avatar
Vlocity
I do all of my own work...I did an engine swap in the 928 a year ago and the year before that I changed the car from an automatic to a 5 speed with limited slip.
The floor is due for a repainting and I think I'm going to try painting it with an epoxy this time instead of the concrete "stain" I am going to try and do it in a black and white checkerboard pattern.
It'll be a lot of taping....but I plan to use a laser to set up nice straight lines.
Regards,
Ken
Old Mar 24, 2005 | 12:24 PM
MBMB's Avatar
MBMB
Why not air conditioning? It's 99 degrees and 100% humidity here much of the year -- kind of like the womb.
MBMB's Avatar
MBMB
Thank you all for your suggestions. I'm starting a notebook.
Old Mar 24, 2005 | 12:59 PM
Flint's Avatar
Flint
I can't imagine that Testarossa is worked on in that garage, at least. Though I would expect it to leave some spots.
Old Mar 24, 2005 | 01:09 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
If you have the power capacity in the box have the electrician set aside and maybe even install outlet boxes for 220 power at 20 30 and 50 amps. You can never have enough outlets in a shop. You can always hang a chainfall from a reinforced roof member, the gantry beam is very useful for working on heavy implements, but prolly overkill for a car shop. The drains in the floors are key and very worthwhile to do now. I have them in both garage bays at the house, all three shop bays and in the floors of both large barns. You will be surprised how often you use them.........Don't forget to over-do the lighting....most garages (including my shop) do not have enough light......I am gonna fix mine, but it is a PIA after the fact......
Old Mar 24, 2005 | 02:43 PM
Jon B.'s Avatar
Jon B.
I don't know if any of you know James Morrison, but he just built a new house and it has an attatched six car garage. Fully climate controlled, and houses his two GTS', his S4, his '81, and his GT2 Race Car built off Mark Andersons old car. He also has a 32" Tv with Satellite/DVD/VCR and full Bose Surround sound. It's nice to be able to clean cars in about 74 degree weather when it's about 90+ outside! Has the hookups for two lifts later on as well, I forget what power source it is...220v? Very cool.
Jon
