4 CYL MODE
Thanks for all the responses guys. David sent me a relay, which I am headed out to install. Hopefully that will clear things up. Is there a way to "bench test" the temp probes????
UPDATE
OK folks, the "bypass" relay works!!!!!!!!!!!!! As stated above, David Roberts sent me the new relay, and I swapped it for the clear relay that has the green/red LED's. Fired her up and drove the heck out of it. No problems, and she felt as fast as ever. THANK YOU DAVID!!!!!!!!!!!!!!!!!
Now, again I ask: Is there any way to bench check/test the temperature probes?????? TIA,
