AN Fuel Lines. Fuel Rail
I want to convert the engine compartment to AN. Does the 944 fuel line kit work on a 928? (the kit converts metric lines to AN at the rt fender)
Is their an aftermarket for the 16v fuel rail? I guess the last option is the metric to AN fittings. I would need 1 for feed line to engine, 4 for the fuel rail. Where could I buy?
I've thought about this too for 32v cars. I don't think it would be horribly difficult to just have new fuel rails fabbed that have AN fittings on them... then get some aftermarket dampers/regulators/fuel pump. The only problem I see is the fuel cooler... might need adapters for that.
For a fuel rail how about 1/2 bulk rail and tapping in four 5/16 hose barbs. Each side. Easy to do with a drill press and pipe thread taps...........
