Dumb Chip Question
Rest in Peace
GW;
The chips are installed inside the LH and EZK boxes. You need to remove them from the pass. footwell, (6mm allen wrench and 10mm socket) pry the little metal tabs apart (w/o breaking them), carefully remove/install chips and replace.
Maybe a 40 minute job start to end.
Call me if you need any help.
Scott
Scott
Note the orientation of the EPROMs when you remove them, you can install the new chips backwards! There is an indentation on the chip package that matches the indentation on the socket.
Also, note the number on the EPROM tags so if you ever decide to put the stock EPROMs back you know which goes into the spark controller and which goes into the LH. Store them in a safe place. I've had customers who wanted to go back to stock and lost the stock chips.
I put my original chips in my glove box. They would get lost or broken anywhere else.
As ususal when handling electronics, ground yourself first. Electrostatic shock can damage these things, according those little warning labels.
