This has been discussed many times before and there is other thread about Devek lever lenght active right now. Desided to start new one anyway as I don't remember comparison pics like these being up yet. Red short versions are from 928 International. Don't know if Devek's is same or not.
From left to right: '78 4.5L factory lever what has been shortened by about 35mm '78-'84 928intl short shift lever '92 GTS factory lever '85-'95 928intl short shift lever
Measurements: A = From center of lower pipe to the top notch (this might be few mm off but if wrong all are same mm wrong) B = From lower pipe center to upper pipe center C = Pipe inside diameter (within 0.1mm same on all four) D = Pipe lenght (all exact same)
'87 S4 measurements on the way within next week or two unless someone already has them on hand?
I had one installed and I was told that the OEM springs cannot be reused and that there are no new springs for installation with short shifter (928 Specialist and 928 International are the same part, I belive Devek's is the same). Is that true? I have serious problems downshifting, specially from 4th to 3rd. If I want to accelerate in 3rd, It will not dows-shift until engine RPM drops sufficiently. Is that normal with short shifter?
Didnt put the springs back in mine the instuctions didnt call for that. Did you clean and lube the shafts as specified. The downshifting would be more of a clutch problem or syncros. Did you replace the four bushings.
Best of luck Voytek
Thanks GG,
I did not replace those four P/N 999 924 002 40 bushings, or slide bearings, and I am not sure about cleaning the shaft. My OEM lever was downshifting from 4th to 3rd like a charm - with one finger and no delay (with all new clutch, 66K transmission, and Mobil1 75W-90 oil). It was really smooth - no resistance when pushing from 4th into the 3rd and immediate acceleration! Now I have to struggle with short level for a few secondes before engine RPM drops enough allowing level to eventually snap in the 3rd. Can You, or anyone who insrtalled it, go from 4th to 3rd with no delay?
Thanks GG,
Voytek,
Even without bushings, the shifter will still work - and looking at Erkkas pics, you can see why the springs cannot go back in with the after market units: their shaft is centered on the pivot 'barrels', unlike the OEM shifters.
Is it possible you have the early short shifter (49mm centers) installed rather than the correct 35mm center S4 unit? Easy to check, and if that is OK .... then with a downshifting problem ( that taxes the syncros), you might want to check the stroke of the slave cylinder, or bleed it to assure complete disengagement.
Just a thought to check elsewhere, as the shifter linkage is so dead simple.
I did this for my 86'. The benefit of doing this mod over purchasing a pre-made is that you can cut the length to your comfort and still maintain a "short throw". Mine works great.
Looking back all the threads found through JKelly's link we would need to get S4 and Devek (do they have one or two versions?) levers measured to have data on all variations. Or is there more factory versions than '78-84, '85-89 and '88-95 (on '88 in CS and SE)? All '78-84 have that horribly long lever or is there semi short factory version for '8x-84?
PS. There was some talk on one of the threads about gear lever wanting to stay between 4 and 5 when in neutral. I have since learned this is design issue and all gearboxes up to end of '86 model year should have lever in 4/5 slot. One spring was changed in S4 box to make it stay between 2/3.
In the first picture, I believe the '78-'84 928intl short shift lever (second from the left) would have a real difficult time fitting in an 85+ model. The distance between the shift linkage bushings is too great; therefore, it is made for the 78'-84'. The 78-84 factory lever (broomhandle), barely fit on my linkage and I had to grind the very bottom of the shifter more round, like the aftermarket shifters are. The squareness of the bottom of the shifter would catch on the thick sound deadening material in there and tear it up.
