Easy way to get PS pump connections off?
In my aging brilliance , I put everything back together after doing the TB/WP and PS Pump, but forgot to put the crush rings on the fluid line connectors I flushed the system when I put the new pump in and had no leaks, so it slipped my mind.
It's ok, I forgot to order new ones and that's why it didn't occur to me to put them on, so now the new ones will be here this week and I'll be fixing it over the weekend. Anyway, (crossing my fingers, toes and everything else), is there a way to get those lines off without removing everything again?
Thanks!
Thanks!
Yeah, depends on how big your hands are. I put the fans back in before putting the resivoir back in and reconnected the lines at the top. Not the easiest thing ever. At least Dexron is easy to clean up. It'll take you a bit but you should be able to get your hands down in there. Seeing what you are doing is a different story.
