Need a CarFAX, Please!
Looking at a local 928 S4 and needed to check the carfax if someone could do that. Looks very promising and has been gone through already..
It's an 89 S4 with 89k on the clock.
"Zero miles on complete major service, including timing belt, plugs, fuel filter, trans fluid change and brake fluid flush. Original paint. Dash does have some cracking. Door panels are excellent. Leather on seats is average to above average, but not excellent all over. Body is excellent. We serviced everything we could see, including new steering rack boots, tie rod ends, brake flush, new axle boot, parking brake adj, etc."
VIN: WP0JB0929KS860571
Thanks!!!!
Thanks!!!!
I have run a report, which I can fax you. There is no bad news in it. For some reason, there is no odometer history - no way to check if the miles are correct or not. It is thought to be a two owner car, from Virginia, then Texas.
