Lucky in Vegas
Range Master
Pepsie Lite
Pepsie Lite
Classic ride height problem......set it to specs and you will be fine...........
The Parts Whisperer
Originally Posted by Bill Ball
I would ask for a refund. :-)
The Parts Whisperer
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by mark anderson
I wish it were that simple. Most of the tire wear can be atributed high g forces in the turns which is why you need some negative camber but when you are accelerating out of the turn you are using more the inside.
Like I said, set your ride height up (try a couple of inches) and you won't wear the tire like that at all.......I promise..........
please see the ROFLMAO........
