928 Forum 1978-1995
Sponsored by: 928 Specialists
Surface Rust
Old Feb 9, 2005 | 07:18 PM
1981 Shark's Avatar
1981 Shark
Default Surface Rust
I live in Louisiana, where it is impossible to get away from moisture. Mine is not an every-day driver and after a few days, I notice that there is minor surface rust from moisture built up on the rotors' surface and the hubs. While a couple of stops take care of the rotors' rust, I'm looking for a remedy for the hubs. I've tried to keep them wiped off, but climate makes this a losing battle. I don't want to use anything that will damage the brakes' from a performance standpoint, but am thinking about appearance, too. Any suggestions?
Old Feb 9, 2005 | 07:20 PM
bigs's Avatar
bigs
Dean of Rennlist, "I'm Listening"
Drive the dang thing more often!!
Bigs - Tulane Med School, 1975
Old Feb 9, 2005 | 07:25 PM
1981 Shark's Avatar
1981 Shark
I'd like nothing better, but again that moisture (rain) thing! Call me what you will, but I don't drive in the rain; way too many morons that don't know how to drive in dry conditions, let alone wet! If you think it's bad in the rain, you ought to see when it gets below 30F for a few days; ice capades!
Old Feb 9, 2005 | 07:29 PM
Adam C's Avatar
Adam C
No - he's right I get this on my brand new Zimmerman cross drilleds. I am thinking of paint - eagerly awaiting answers.
Old Feb 9, 2005 | 07:30 PM
Jim bailey - 928 International's Avatar
you can paint the center hub portion with any high temp paint just do not get paint on the surface where the pads ride
Old Feb 9, 2005 | 07:32 PM
1981 Shark's Avatar
1981 Shark
What type of specs/temp rating does the paint need to have. Also, how much prep is needed; obviously the rust needs to go first, but what else?
Old Feb 9, 2005 | 07:43 PM
I have used flat black BBQ paint before also engine enamel . Just sand off the rust ,mask and shoot
Old Feb 9, 2005 | 09:00 PM
Daniel Dudley's Avatar
Daniel Dudley
Eastmans restoration catalog has high temp paints as well, in many colors
Old Feb 9, 2005 | 10:43 PM
1981 Shark's Avatar
1981 Shark
Good tips. Thanks to all.
Old Feb 10, 2005 | 12:50 AM
G Man's Avatar
G Man
I wouldn't think the hubs would get hot enough to warrent high temp paint. Like stated above I would clean up and spray with a decent paint in your favorite color. You could even spray the hubs with clear if you don't want color. You just need to keep oxygen from getting to the surface.
