Wheel offsets, front 47mm - rear 52mm
I talked to Tom @ 928 specialists, I think thats where I called, but anyway he said the wheels that he sells for the 928's are front 49mm and rear 52mm offsets. Will a 47mm front and a 52mm rear, be that much different, my car is lowered about 1.5 inchs. I am looking at AT Italia Rivas, like the Green Goblin's car here on rennlist, but I want to know if they will stick out in the front or be tucked. If they stick out in front they will not clear my fender.
The Rivas at 47mm have been reported to fit on a properly set up car. However, I'm willing to be that they will rub if your car is lowered that much. I'm running 47mm offsets on my S4, and they rubbed until I set my ride height correctly (the car was about 1 1/2" too low coincidentally). As it is, I haven't really pushed the car hard to see if they will rub under more extreme circumstances.
-Gary
-Gary
Rennlist Site Sponsor
There is no "Tom" at 928 Specialists...
The wheel/tire expert at 928 Specialists is named David Roberts, although Thor is getting better...
Rennlist Sponsor
Yes, and if it was Thor that you talked to you can easily tell the difference between Tom's (@928intl) and Thor's(@928sp) voices....Thor's is MUCH deeper, sort of like a very low pitched growl :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Rennlist Sponsor
Oh, I just talked with the manufacturer of the RIVA's, they are still indefinitely "backordered" on the 18" rear wheel. It has been this way for over a year and no availability date is shown, hence the reason we no longer offer those.
BTW Gary is correct, the RIVA's are a "compromise" fitment (concerning fronts) and work OK if you use stock height/alignment settings and proper tire size (225 front). Any deviation from that and you may have rubbing issues.
Rennlist Sponsor
>Can you still get the Rivas in 17"?
I am pretty sure those are on "terminal" backorder also, but will check and let you know if otherwise.
Rennlist Sponsor
>Do you offer the 18" BW Motorsport wheels like the ones on your 85 Euro?
> I don't see them anywhere on your website.
BIG surprise concerning those coming in a few months. Final casting is approved and production will be starting soon. BTW, I get the first set!
Hint - Reverse drop center :-)
I might wait then, how nuch will they run, and do u have better pics?
Rennlist Sponsor
Justin,
Wheels will be the same style and look, just made in a "Reverse Drop Center" style so the centers will be more "open" and will also be available in 19s. Pricing for the 18s should be within a few hundred of what they were before, approx $2600-2700 for 18s with 9 " fronts and up to 11" rears.
